Advice on Generator vs Alternator
Rustedjunk
Since my generator is fried, I have to replace it. My car is going to be 12 Volts. And my 47 has been rewired with a remake of the original wiring harness. I've seen converted generator rebuilds on Ebay from $170 - $200 producing 40 amps. Powermaster sells an alternator that looks like a generator for $375 producing 90 amps. Then on the Ford Barn I read a thread and discovered EJ Whitney and had a great conversation with him. His alternator conversion using my existing generator cost around $450 producing 40 amps. That one is a little steep. I want an original look to my 47. I'm looking for input and advice. What would you suggest?
More is not especially better unless you have a reason for more. Even if you have unlimited funds.
Don't go chasing higher amperage unless you have a definite need, such as a powerful amplifier or special lighting OR if you need to leave the headlights on for hours at a crime scene.
Admittedly I'm also against converting to 12v. I would certainly investigate the reason for your generator getting fried soas it doesn't recur.
Then I'll go with a 12V / 40 amp generator, and get a 12V regulator from a Thunderbird or something. Thanks you all for the input.
I am in OZ, so our available old parts are different.
I got an EH holden 12 volt generator and removed the mounting ears and fabricated a lookalike sliding bracket using the original sidevalve strap..
At a glance and not so expert V8 people, it passes for original (look).
Much nicer than an ugly modern alternator.
Pooch - Sounds like a reasonable compromise! I am rebuilding a '39 3 ton Ford flat tray and looking at somewhere like $A800 for a 12v new 6V replacement in Oz or similar out of US with exchange & freight. Be interested in a photo.
Maybe there are cheaper rebuild alternatives to go from 6 - 12V Phil
What part of your generator is "fried"? If its the coils you can replace them, I did. I am running the old 6 volt case and armature with 12 volt coils and a 12 regulator. I have had no issues, but its only been a year. Oh yeah, mine is the G series engine which has a generator all it's own.
I respect your desire to stay "stock-looking" or even "stock-stock" .... But whatever form or appearance an alternator may take, functionally I like that they (1) are always charging, (2) have no brushes to wear-out or malfunction, (3) don't require an external regulator, (4) have less external wiring, and (5) they are inexpensive to repair. There's a old electric motor repair shop a mile fro m me which will test and repair an alternator within a few hours. The internal regulators are pretty much standard configurations and fit many housing.
My '47 came to me as a non-stock 12 volt and uses a 63 amp GM alt. With a good battery on-board .... Bright lights galore even at an idle. I'm good without LED's (which may need resistors to function).
An aside .... Bubba has a friend who wires alternators to use an external regulator.
No Chinese regulator parts please .... their longevity stinks.
The armature is fried. I don't even know where to get parts to rebuild one what to get.
Gday Phil, here is the EH genny....could even be FE FC, FB, EK, EJ, dunno, they are all alike, just the one I have in car ATM does not have the cutout sections at brushes, not that that matters.
I will have to look, maybe one is Lucas and the other Bosch.
Took a bit of hunting at swap meets to find a wide pulley as all holdens have narrow ones.
Dunno what the pulley is off but it fits and I found 2, This second genny will go on my bus.
As can be seen, my engine is open , so a modern alternator would just not do.
I'm a Whitney fan! Looks original and fits (because it's your case).
They didn't use the case on the one they built for me just the ends and front mount.I believe they make a new larger diameter case from aluminum tubing.
The center is aluminum tubing, but think your confusing Whitney with Power Master on the diameter. The Whitney keeps the original dia.
Dlete
