Hunterspeedandkustoms
Hey Everyone,
I've had this Model A for only a short time. Usually I haven't had too much trouble getting it started, but recently I'm having problems.
Ignition on, GAV open, gas level or steering wheel set to 4 o'clock. First time I press the starter switch the starter spins up but then dies off after a few seconds feebly. Subsequent attempts I can't get the starter to spin up with any vigor. Eventually I can barely get it to turn over after the third or fourth attempt. Amps look to be low so I thought I might have an old battery in need of replacement but after pulling it I see it was manufactured in late 2017.
I tried replacing the coil. Maybe a bad starter? Any advice appreciated!
