bigd1101
Rebuilt engine with a rebuilt Teapot two barrel. Still a tad rough idle.....messing with the two gas/air jets and the idle screw. Is there a magic formula here? All the way in easy, 1 and 1/4 out on the two jets and setting a decent idle. She smoothes out if I set the idle high enough, but I don't like it that high, especially when she first starts up with the auto-choke. Yes....all settings done at 160 engine temp. Cleaned the plugs, checked all the plug wire connections, new coil, same results. Any thoughts?
