pennies4pennies
Another problem. I am trying to make sure my header is in place. On the first picture you see the cover flush with the wood, but then my screw holes inside the car do not match up as you can see in the 2nd picture.
So now if I move the cover to match the inside holes then I have to move the header out which in turns does not give me room for the screws to catch the wood on the inside plus the front of the cover will now have a gap by the molding. Which is the correct way for the header to be placed.
Either way I will still have to put a spacer between the header and the top cross bar.
I'm thinking the first picture is right but I would have to drill out wider holes on the cross bar and put the inner screws on a slant to catch the wood fully.
Frank
Frank
