The brake system on the A is 60% rear and 40% front.
After relining all shoes, arc a pair to each drum ( keep each pair associated with its drum); the purpose is because each drum when turned will no doubt measure differently.
I start at the brake pedal and adjust the rod to the brake cross shaft so the clevis ends are vertical on the cross shaft. I then attach the rear brake rods, pull out the slack that is built into the rear brake system, then adjust the rod so the pin slips into the brake cross shaft clevis, set jam nut on rod. Then move to the front brake rods; attach the eye to the brake cross shaft, pull the slack out of the front brake cross shaft lever, adjust rod so clevis pin slips in. set jam nut ( leave front brake rods not connected at this time). Adjust rear brakes shoes so they are lighty touching the drum. Drive A on a smooth level black top street at 10 MPH, jam on brakes and make emergency stop ( this will leave black skid marks on the street (the length of the marks should be equal and the car should not pull left or right) adjust rear brake shoes and continue testing until emergency stop skid marks are equal and car doesn't pull left or right . Now connect front brake rods, adjust shoes until they just touch the drum then back off 3 clicks. Make one more emergency stop to make sure car doesn't pull left or right, and adjust accordingly.
During the above tests, I am constantly touching the drums checking for excessive heat.
I use rivited woven lining, I myself prefer to not use bonded lining as its a harder lining; a softer lining with mechanical brakes seem to provide better brakes.
As Marco said: be sure to have your 15 degrees forward of center on your front cross shaft arm.
Once you have your brake cross shaft correct, your rods adjusted correctly, you shouldn't have to ever touch them again, only adjust shoes as they wear, and when you have no more adjustment its time for new shoes.
This method has worked good for me, probable others have just as good results doing there brakes a different way.
Ron
