adjustable lifters
41 fatty
1941flathead ford 85hp: adjustng tappets@.012" intake, .016'exhaust. Should I measure just as opposing valve is starting to close, as in exhaust just starting to descend, check/ adjust intake and likewise with exhaust/intake?
Lifter all the way up then one full turn on crank to put lifter on heal of lobe. that's the way i just did mine.
If you can get an older “Motors Manual” they show a sequence where you only have to turn crank 4 times to adjust all valves. I used it and it did save time.
Be careful, some methods do NOT put the cam exactly on the heel center.
You will NOT get an accurate adjustment that way.
