Adjustable draglink
I took a 43 1/2” tie rod and cut it down to 21 1/2 “ and used tie rod ends to make the shortened version 24 1/2 “ the same as the stock draglink but adjustable to be longer. If anyone can point out any problems with this please don’t hesitate to let me know. Jerry
When I made mine I set it to the length that I needed at mid adjustment so that it could be adjusted either way if needed
Tie rod ends can interfere with the driver's side steering arm, etc. The end clamping bolts may need to be adjusted or modified for clearance. Dry run position the drag link to check clearances of components on both sides of the front end..
