Russell Reay
Les Andrews says to set toe-in @ ~1/16" at wheel hub level (~14" above ground). Paul Shinn uses a commercial toe-in gauge and Phil Brown (4/10/23) uses a home-made wooden pair of brackets, and both set the ~1/16" toe-in at about 6" above ground. Recalling my 10th grade geometry, the difference at 14" will be more than double the difference at 6" unless the camber is 0 degrees. Keeping in mind the width of the marks on the tape measure or pencil marks makes the evaluation of 1/16" a little iffy, what is the correct height above ground for measuring the toe-in?
