Hi Tom. In your article on the Tach it states "Two wire leads from the tach attach to the two coil primary terminals". Does that mean your tach is 'Hot' all the time? Neg side on coil is connected directly to terminal box on Pos ground system? Please explain.
I had to rewire so my ignition switch was 'before' the coil instead of 'after' like a original Model A should be wired so my tach was not powered up all the time.
My Victoria is wired as Henry ordered. It is six volt positive ground. The ignition switch is electrically below the coil. There is always voltage sitting on each coil primary terminal. When my tac is connected the two wires also see voltage. However, there is no current flowing thought the coil or the tac until the ignition switch is closed and the points are closed. The tac does not become active until it sees a pulse from the primary winding of the coil. That only happens when the points close. When current is flowing through the coil, one terminal is momentarily at ground.There is no other ground on the tac so there is no current flowing through the tac when the points are open or the ignition is switched off..
Tom Endy
I like your gauge set up but what really caught my eye was your steering column support...was that a commercially obtainable product or is it something you have made up ? if so, I would be most interested to see it in detail . Mt car is right hand drive and your bracket looks to be adaptable for both sides.many thanksHoz about something like THIS?
Ruth' Can you show how you wired the coil after the ignition switch? I sketched this out and found that I would have to break into the ignition cable that goes to the distributor to do this. Not sure this is possible. Jack
...what really caught my eye was your steering column support...was that a commercially obtainable product or is it something you have made up ? if so, I would be most interested to see it in detail . My car is right hand drive and your bracket looks to be adaptable for both sides.many thanks
Vic....NZ
If the gauges pictured belonged to Y -Blockhead , I meant no harm in post #12 .
It may take a half second longer to look at all the gauges with them mounted all over the place but the only one I need in autocross is the tach.
I like these locations because all the wires and pipes for the gauges are out of sight except for the tach.
