oldmotorsguy
Just about done with this "little" project. Bought a 1917 Touring, no starter. Thought to self, 'how hard could it be to put a starter in this baby??" Just slap a starter ring on the flywheel, add a starter and battery, there you go.
Not so fast, there, Kimosabe. As I proceeded, lots of little things to keep in mind:
1. I had a spare hogshead with a starter mount. Check.
2. I began swapping out the pedals from the non-starter hogshead to the starter hogshead, and Bob B. of Bob's Antique Auto mentioned that the low speed pedal needed to be changed since the old one would interfere with the bendix cover. OK, got that swapped out.
3. Rather than monkey around with putting a ring gear on a non-starter flywheel, I just used a 1920-something ****** with complete flywheel and ring gear. Check.
4. Early T blocks do not accomodate a generator mount. Considered altering the generator mount to switch it to the driver side of the engine and power it with the fan belt. Jury is still out on that one, Bob. B is not optimistic this will work out very well.
5. I now notice that the low speed pedal linkage arm (the one I just swapped out) is now quite a bit out of alignment with the lower transmission linkage (the one that moves the brass fork in and out).
I am considering heating this arm up with my oxy=acetylene unit and bending it into alignment. Then again, this piece seems to be cast iron, and that may not work out all that well. Or, I have another linkage part from a 1926-7 that looks a bit better aligned, I could just pop the pin off of that one, pop the pin off of the current one and swap them out.
ANY OTHER SURPRISES IN STORE FOR ME AS I PROGRESS IN THIS PROJECT? They seem never ending for a simple task that began "just put a ring gear and starter on it."
