Add Temp Gauge
DFS
Someday I may restore or replace my liquid temp gauge that has lost its red color, until then, any recommendations for a temp sensor and gauge I could add to the spare port on my heads? Still 6V, positive ground. Thank you.
This is on my 53' Merc, still 6 volt pos ground. Just replace the bulbs with 6 volt bulbs. Got them at O'Reilly's.
I run a vintage Stewart-Warner mechanical I scored at a swap meet as well as the stock setup. Works great and looks like it has been there for decades. If you run a mechanical you only need to worry about using a 6V bulb for the illumination
