A previous owner of my 30 Tudor added a small copper line from the oil port in the side of the block to the timing pin hole in the front cover. I assume their intent was to provide additional oiling to the timing gears. However I have been told several times that this is unnecessary because a large volume of oil is dumped into the front housing from the lifter galley. I discovered yesterday that this oil line had broken at the ferrule. Does anyone see any danger in doing away with this line completely? Is it possible that a rebuilder may have blocked the oil passage between the lifter galley and front housing somehow and this line is the only lube the timing gears are getting? Worst case scenario, I have to remove the front cover to check. Thanks for any insight you may be able to lend.
-Brian
-Brian
