dmaxweb
I have a 30 coupe and I need to install backer plates under the sub rails for mounting the outer front seat seat belts. I've seen comments that you can just slide the backer plates in from the opening in the rear wheel well and then thread a bolt in from a hole drilled in the sub rail. Maybe I'm missing something. The opening from rear wheel well is way to small to reach into and hold in place to thread the bolt in from above. If I remove the rumble seat floor pan (just machine screws/nuts around the perimeter) will I have access to the underside of the sub rails?
