Scotty's 52 F3
I got a couple old Accel Dual Point distributors for next to nothing so I adapted one to my 52 8RT.
I'm having issues finding the right springs to set up my advance. The springs that were in the Accel to start with are the lightest I have. I'm only running one at the moment and the advance doesn't start to come in until 1100 RPM. Anybody have a recommendation for a source for some lighter springs? The other springs I have are from old advance kits I have and are heavier.
When I set initial timing using a vacuum gauge, max vacuum @ 500 RPM then back off and drop 1", my initial is 6 deg advanced past timing mark. Starts fine.
The max centrifugal advance is 25 deg, all in by 2000 RPM but, doesn't start coming in until 1100 RPM.
I still have to dial in the vacuum advance. Just checking as is gives me 10 deg. 16 deg @ Idle and 36 deg @ 2500 RPM, No load. I can mess with that after I get the springs worked out.
I only hooked up one set of points and gapped @ .014. I can hook up the other set but, my engine is stock. Keeping it simple.
I know I can buy a distributor from Bubba's but, this is part of the fun.
Scott
Scott
