Hi Dave,,
Have you removed the body ?. I went to remount the body on my 30 coupe and the accellerator didn't work properly..
It worked before ! Turned out to be the rubber pad's on the body block's were too thin. I happened to look at the old original "Pad's" noticed how much thicker they were...
Installed the correct thickness of pad's and the accelator now work's correctly.. could that be what happened to your A ?
Greg out west,
