If you run an electric fuel pump with the original mechanical pump you will need one that shuts off in the "open position" so the mechanical pump can still draw fuel through it. Most of them shut off in the closed position so the fuel doesn't flow pack down the line and into the tank. Mount the pump as close to the tank as you so it can easily prime. Stick a filter between the pump and the tank, that protects the pump. A lot of older fuel hose, carb kits and fuels pumps have rubber that is not designed for alcohol use. A vintage pump might fail on you. I only use the fuel line recommended for high pressure fuel injection. It is made from better material and will last a lot longer. Somebody mentioned the outer hose is not fuel proof, that is 100% correct, it will rapidly turn to mush if it is submerged in a fuel tank. There is a special submersible hose for in-tank electric fuel pumps.
Airtex pumps don't have the vintage look of an old Stewart Warner or AC but they work pretty good. They make one that is low pressure and open when in it's in the off position. Make sure it says its compatible with alcohol. Most manufacturers have upgraded their pumps and carb kits but there are still older ones on the shelves being sold. All electric pumps eventually fail. If you are on the road and this happens, turn the key on and smack the pump. It will usually start pumping again to get you home where it can be replaced.
