Cape Codder
Is it possible to change the AA Transmission with a F-150 transmission? the truck presently has 5.16 rear end. Will this help to get the truck up to 50 mph with less RPM then original trans.?
Another posibility would be the complete rear axle from middle thirty’s Ford truck they may have a lower numerical ratio. I think the bell on the torque is compatible and brakes are rod operated thru 1936.
Check, don’t take my word on this!!
It was a lot of machining. When I bought the ******, I didn't know which OD it was then later someone on the FB posted the letter code so you can decode the name plate on side of ****** to find out which OD it is.
