John Walters
Looking in various publications I have seen AA trucks pulling heavy loads. What was the engine in the AA? A heavier duty 4 cylinder?
A "wider disc"? What do you mean? Bigger diameter or thicker?
Early 1928 were multi disc clutches and all the same.
I was asking what you were referring to by a "wider disc".
I am still wondering.
I always thought of the A and AA discs as 9" and 10", as that's what I read years ago. I guess the measurment could have just been rounded off to the nearest inch. Anyway I bought an NOS 10" disc at a swap meet for the 1930 AA I worked on, and recently I found an excellent slightly used 10" that I'll use sometime. The 10" does overlap the square openings in the pressure plate, but that doesn't matter.
