38 coupe
I have a neighbor with a 31 narrow bed pickup equipped with the heavy four transmission. The problem he is having is gear oil is leaking out past the shift rails in the top. I looked in the green book (I know, not the best source of information for Model As) and the line drawing of the top indicated there was a plug or seal or something that sealed off the ends of the shift rail bores. This makes no sense to me because the shift rails extend past the edge of the shift cover when you put the transmission into 1st and 3rd.
I am an early V8 guy, not a Model A guy. I have owned flathead V8s with the same four speed and don't remember them leaking from the top. What experience does everyone have with this? Is there a known solution to stop the gear oil oozing out?
Thanks.
Thanks.
