Fullraceflathead
Does the special U joint bolt onto the output shaft on the AA 4 speed transmission? I have mine apart and it was not bolted. The U joint is just kind of floating on the output splines.
Does the output shaft have the threaded hole in it?
See: https://www.snydersantiqueauto.com/product.htm?pid=979685&cat=41815
