I found a nos set at a swap meet that I think were WWII era. They didn’t have any shims and were marked wrong as to left and right. My original thrust bearings cleaned up and looked better than the ones in the set so I used them. (They were roller bearings and the replacement were ball) I found some shims from one of the on line supply places. I used Snyder’s bushings. They were better than the WWII ones and had the correct grease grooves. Grainger has a thrust bearing that I think would work but since my original ones cleaned up good I didn’t order them. I had a local truck spring shop ream the bushings.
