Ron, I suggest that you and your friend review post #3. It is a worthy list of checks. Your carb substitution may account for the jet size item, but it would help to methodically perform the list of checks Neil has written and then come back with what you found on each one and by what method you tested it. There are a couple more easy items that I or others may suggest after receiving your followup.
FWIW, The last item in his list is a common failure point. "loose, dirty or corroded connections" can reduce voltage and thus amperage flow in the ignition system causing weak or intermittent sparks. Low voltage/amperage may not adequately saturate the two internal coils and thus secondary circuit voltage is missing or weak, especially as load or rpms increase. (And now I'm espousing things way above my pay grade!)
If you or your friend or another club member have the Les Andrews (blue) book "Diagnosis and Troubleshooting" chapter 2 page 32 has a quick and easy test to help you determine if there are issues in the wiring. Other pages have easy tests for battery grounds and cables.
I hope this helps you.
