I'm experiencing a stumble by what appears to be an intermittent electrical short when accelerating between the rpm ranges of 1800 and 2000. My theory: as I accelerate I occasionally hear the radio or a cd hesitate ever so briefly thru the 1800-2000 rpm range enough to cause a CD song to be interrupted. My thinking is the brief electrical short affects the fuel pump enough to cause the A/F ratio to jump, which it does when viewing A/F numbers on the laptop in the garage, under no load. So I'm assuming the electric fuel pump is also affected causing the Air/Fuel mixture to rise ever so briefly from 14-15 up to 17-18 in.-Hg. From idle to 1800 rpm smooth acceleration, 2000 on up to 4000 rpm, smooth acceleration.
My setup: '35 Ford 5 Window Coupe, late model Flathead V8, 12 volt system, 100A alternator, 2 – 1988 Ford Escort TBI's, Megasquirt II V2.2, Mallory Unilite distributor, Mallory coil, Mallory Hyfire 6A Microprocesser controlled CD ignition, electric fan, radio/cd player, T-5 manual trans.
I THINK it all started at the end of last summer when I got caught in a rain downpour about 1 mile from home with no hood on the engine. When I got home, I wiped everything down. The next day I noticed no power and realized the system 50A fuse had blown at the battery. So with everything having a chance to dry off overnight, I replaced the fuse and it started right up.
So far, I've: verified solid tight grounds, had the alternator load tested at a shop, new fuel pump, 12v battery tests ok at rest and overnight holds its charge (thinking of having it load tested at the local parts store), replaced the Unilite module, inspected the advance springs below the module, replaced the coil, inspected the distributor cap for cracks, replaced spark plugs and wires, replaced the wide band O2 sensor, checked for loose wiring at the fuse box, replaced the injectors, cleaned the pin connectors at the TBI's, disconnected the wiring to the Classic gauges (tach, voltage meter, oil pressure in case there is a short in the gauges), cleaned the pins to the Megasquirt ECU, replaced the vacuum line to the MAP sensor,…all with no change. I turned the fan, radio, and lights off…no change, I even removed the three associated fuses… no change.
I'm running out of ideas...after I take the battery to be load tested. Arrrrgh!
Ken
Ken
