Plainsman30
We are in the process of rebuilding an engine for our Model A. The engine will be inserted, counterweighted, and flywheel lightened some to compensate for the counterweights. The only performance modification is a 5.5 head. The carb, exhaust, valve size, and ignition are all stock as we like the stock look. The car is used for some touring and for short evening drives. I like the low RPM pull of the "A" engine. We don't plan to drive much over 50 or 55 as my wife protest if I go faster, but would like it to do 65 if needed. I have read the B cam has more power on the road, but I suppose it would lose some on the bottom end. I see reground cams can be purchased at Snyder’s for under $100. Would and A or B cam be recommended?
