Bassman/NZ
This is the C59A in my AV8. It is dead stock with the exception of duals and Smithys. It runs 65lbs at startup and drops to about 40lbs when hot. It's backed up with a 36 trans and 47 rear.
Down the track a little I plan to run twin carbs, a set of headers and mill the heads to raise compression a bit. However, it runs pretty good in a light car, so no priority on the mods.
