'A' hubs on t front axle
anteek
I'd like to put "A' front hubs on a trailer I have with a 't' front axle. I've seen it done before on trash trailers. What parts does it take? The wheels used were 16 disc,so they weren't 'T'.
If I recall, it's the T inner bearing and A outer bearing. You have to machine the axle shaft for the outer bearing as the A hubs have a thinner profile. You may or may not have to cut a longer groove for the lock washer or add a spacer washer between the bearing and lock washer. The T shaft is longer and will stick out a ways from the hub.
