NCSUDucker
Couple of questions. All fluids have now been replaced, I'm learning to double clutch pretty well, at least going up thru the gears�� I had the oil pan pulled and the sludge (about 1/2") cleaned from the oil pan. I know the purist will get me but had some bolts break off in the exhaust manifolds so we went with the Fenton cast headers. We didn't mess with the carburetor to start with as everything was running smooth. Was excited to drive it with the other day, made it about 15 miles before some trash of the carburetor stopped fuel delivery. It would settle out and start back up but ultimately had to get a roll back. Anyway, I had no smoke in the cab before all of the work was done, maybe a touch out of the exhaust, but before the carb called it quits I was getting a ton of smoke in the cab. When you guys fill the oil do you leave it a little low? It's filed to fill line, wondering if that might cause the smoking issue. I know it could be the rings as well but with it not smoking at all before we did the work, I'm looking for other possible causes. Granted some of it might be burnoff from dropping the oil pan/ filling but I would think that would have subsided pretty quickly. Going to check the road draft tube, anything special for making sure it's clear? Lastly, this one is intriguing, I've read any the cotter pin and the reason for it. The cotter pin is missing and at some point in this truck's history it looks as if someone cut an H with a dremmel tool at the drip hole so that they could *my guess* fold it down/open it? Maybe it was clogged, I don't know. Regardless, the cotter pin is no longer there and the H cut is still there. Is this going to be an issue? Really no way to get the *** end of the cotter pin in without removing the oil pan again (not really wanting to do that). As for the H, short of taking it off and replacing or having it welded I guess I could try a little JB Weld. Granted with a weep hole there anyway, I'm wondering if it even matters.
