I am getting ready to start up my engine for the first time for me. I believe it's been sitting for at least a year.
I read that it's a good idea to pour the last quart of oil into the distributer hole to lube the valves and top end. Is this only after a rebuild or should I do that? I put in 40 weight dyno oil. Does that sound right?
I assume that I should put ant-freeze in the radiator. The cooling system is dry and the po installed a thermostat in the top hose. How much anti-freeze should I put for the whole system considering that when the thermostat opens I will need to top up with water. I know, dumb question...
Any particular anti freeze?
Anything else I should do or check?
Thanks!
Thanks!
