Fred K-OR
Put an aluminum 2-blade fan on it & it will look more original & make it easy to change WP in future.
I took a big gamble and put a 4 blade fan on my coupe. I did not want to take the radiator loose and wanted to put on a new water pump. So I bought a 4 blade fan that bolted to the hub and thus I could put the blades on after I installed the water pump which had the hub installed. Like I said, if those 4 bolts that hold the fan to the hub come out, I will have a bit of a problem. But for now it does the job I need.
