Do as Ron says. It will really wake up that 59AB engine. After carving a little meat out the top of the valve chambers, check the heads for pistons clearance before you mill them. they may have been milled before and if you take off another .050 thou the pistons will hit the heads. BUT if they haven't been milled they will stand .050 mill. You'll be surprised at the low end torque over the 59AB heads. Waltwalt. i have a good set of A heads. would they do anything for my 59ab in a 40 merc. reguards dick t.
