daveymc29
So here's where it starts, I have an A/C unit from Mr. Davis down Texas way. It works well for the first 10 miles or so then becomes a nice mover of air that is in the cab, but doesn't add much, if any, cold to the cabin air. I suspected the fan that blows air through the condenser is not doing it's job so checked after the system had run a bit and sure enough the little fan is not turning. So, I pulled the hot lead off the fan and found that it is powered up and as I hooked it back up it arced and sparked and the little fan made a valiant effort to spin and the just quit, no more movement. I did this several times and each time it did the same thing, fan began to rotate, flashes and sparks as I plugged the hot lead back into the system and then nothing.
So, is it the fan motor and if so where do I find another or someone to repair it? Do I return it to the vendor, Davis? If so I have to ask someone to provide me with his contact information. If it is not the motor, where do I turn next?
Dave
Dave
