yachtsmanbill
- City
- T.R.
- State
- Wi.
- Price
- In ad
Just making some room and wanted to toss the stuff on here before it goes to Edog...PM for details if interested...Prices are negotiable and F.O.B. T.R. Wi. ws
Model A ring gear, complete carrier and two hubs with bearings $15.00
2- 21" 1926-7 wood wheels with large brake drums. Valve stem goles are drilled for chevy rims as well. ROLLER CONDITION Ruff but solid $25 ea.
2- 21" Chevy split rims. Will fit Ford wheels with extra valve stem hole. VERY round and nice joints. One still has air holding tire mounted. I needed the other tire for my spare $25 each or $75 with DECENT tire (little checking)
2 1918-1928 Chevrolet CARTER carbs REBUILDABLE $30 ea Both for $50
1926-27 Ford coil box lid, pitting on rain gutter, perfect latches and springs $20 OBO
Model T intakes $5.00 ea.
Model T differential 1926-27 axle tapers are bad. No drive shaft or radius rods. Was a trailer axle. Will seperate, decent ring gear, carrier, backing plates, spiders, and I would assume, bearings and races.$5.00 each component.
1926-27 rear brake drums. Nice shape $10
STANDARD Model T pistons with pins. Cast iron. $5.00
Used/removed wishbone ball $3.00
Front tie rod. will measure length $5.00
1915 T 3 screw Holley carb rebuildable $15.00
1926 dash plate parts. no internals or meter but has nice meter mounting ring $5.00
Earlier switch plate. No key. switch feels perfect. Script ammeter perfect. Tab type internal mount. Extra switch plate with hole for dash lite. Both $25.00
1925 fan adjuster. no fan. blocked off for race car (!) Excellent bushing. Pulley repaired (bullet hole?) $15.00
AND LAST BUT NOT LEAST !!! By the book, 1908 NRS or 09-11 model T steering gear box. Shaft was cut about 24" a long time ago. Disassembled (removed rivets) No tube or lever quadrants. No cover. This does not have the over steer slot! EARLY!!! Three gears, wheel stub and nut included. When held together turns BEAUTIFULLY! No slop. Nicely polished BRASS unit. This does not have the bendable ears for the control rods! The holes are perfect. It needs to be riveted/assembled as a unit. Thats why I didnt rivet it together. On a scale of 1-10 its a solid 8. $200 OBO trades considered.
Model T front wood wheel hub. Extra holes drilled for speedometer (?) includes inner and out bearings and roller condition hubcap. L or R outer bearing. its the buyers choice. $25 OBO
Model T generator and seperate gear. Gear bore is worn (loose on shaft by .003") sold as CORE $25.00 both pcs.
Spark plug collection Half Model T... some real oddballs in there. Champ Xs Edisons etc. $30 OBO
IMPERIAL fuel pressure pump. Nickel plated. Lokks good AND works! Ideal for speedster etc $30 OBO
Happy Festivus everybody! Feel free to call anytime! Sorry about the long download time for you dial-up oldtimers. This is the 90s after all LOL
Bill 6303888882
Bill 6303888882
