Phil Gillespie
First time for everything and so here it goes.
I'm playing around with a spare 99a Flathead engine. On setting the valve clearances to specs of 10 thou inlet and 12 thou exhaust. I noted that on turning engine over the valves on a few cylinders were sitting off valve seats by approx 10 to 15 thou. Still plenty clearance between lifter and valve.These are the mushroom ended valves with the split guides. A light tap on valve head and valve sits on valve seat. So maybe spring tension on valve springs suspect.
Got a new set of valve springs noted uncompressed length longer than existing ones. Guess what similar senario on some valves on 1 to 4 cylinder bank.
Maybe some valve shims would assist. Nope. THe valves sitting oof the seats all had clearance between follower and valve foot. A gentle tap and valves seat well as not able to slide a feeler between valve and seat. The valves are all free in guides. At this stage I am open to all ideas and suggestions.
Thanks in advance.
Phil NZ
Thanks in advance.
Phil NZ
