94 rebuild kits
fourtydlx
Im about to rebuild some 94s,who makes a good kit,that will withstand 10% eth. here in cal. also have to put long shafts in bases.,thanks les.
KenCT has kits that he makes from proven parts that withstand today's fuels. Also, if you have a question rebuilding, he is only a phone call or e-mail away. John
Thanks John,i have strickly USA made kits but DONT have the long shafts. You dont need long shafts if you use the correct bases on them also depends wich 94's hes talking about.The older type ones48 down do not need extended shafts in you connect together on the drivers side. ken ct.
I have a 94 carb that has an extra rod with spring that mounts to the fuel pump rod.Does anyone have a diagram of this type carb?I keep thinking something is wrong with it because spring does not look like it is held correctly.
Never heard of anything like your talking about.Why would a carb have a rod going to the FP. Send a pic. ken ct.
It's not a 97, is it?
I am sorry Ken,I was talking about the accelerator pump piston in the carb.The pump piston has a spring on it and then there is another rod which has a spring on it connected to the piston rod.
Still not sure i know what your talking about. There is a long spring that goes over the AP flat shaft,i have those about 5" long and about 1/2" diam. I add a spring on the round part of the pusher rod it helps bring the AP back up when you let off on the acce. pedal. not sure if thats the one your talking about. Need a few pics. sorry i have a good stock of ALL 94 parts,cant picture what your talking about. call if you want more info. ken 1-203-260-5945 cell.Any time.
