It's not the washer, it's the valve. You can buy the right one from Charlie's Speed in Fla. www.charliesspeed.com. the new valves are not machined correctly. Charlie buys them in bulk and removes the radius from the shank.
Update. The PV i'm using was a new one from Vintage speed and has no radius but using the round fiber washer, also from Vintage Speed it leaks. I tried the nylon washer and it worked much better but after several hours with the bowl full, the PV was wet on the bottom but not dripping.
