Alaska Jim
Is there a special jet wrench made for the 94 carbs, similar to the one made for 97's? If so where can I buy one. also, I would like to know if the jets in the 94's are the same as holly 4 bbl. jets? thanks for any information anyone can give. all info and opinions welcome. I am also trying to sort out a tri-power set up that came on my new to me 30 coupe with a 272 Y-block. the end carbs are currently blocked off and there is no progressive linkage, only straight (all 3 at once ) linkage. I would like opinions and any info anyone can give to as far as jetting, power valves, and linkage goes. engine has 61 truck heads, valve size unknown. sounds like a mild cam. cam and cam spec's unknown. Timing is currently 16 Deg. on the crank, and a total of about 36 all in. not sure when all advance is all in as I did not have a tach hooked up when the ck for the advance was made. looking for a little help and to be pointed in the right direction to get this set-up going correctly. Thanks in advance for any help----Jim
