!934-35 interior door strap lengths
cabmoneydrain
Hello all, I have a 1935 cabriolet with the early doors (interior handles closer to "A" pillar). It does not have the interior pull straps and Id like to install a set, but need the length and mounting points. Anyone have those? Would have to be total length, then length from straight end to end to adjust for "droop". Then distance from door top edge and side to side.I guess these are similiar to "34 doors. Thanks
Here's a factory of the 35 pull cords
Awesome! I think I'm enjoying discovering the absolute treasure trove of knowledge here as much as the car! Thanks so much, now I have to find venders for the cord covering
Look at the inner metal door panel the original screw holes may still be there.
My doors have two sets of holes; were there two different length of straps used?
Or since the spacing is the same, a fore or aft location for the same length strap.
I ended up using '33 pull rings as I could not locate any repop pull strap kits.
I had seen them listed at one time; but the supply must have dried up when I was looking.
589473
