Assuming you have the nuts off, the carrier bolts are a quite tight press into the carrier ring. They do NOT thread in. I use a brass hammer and brass punch to knock them out. Replacing them, you might put them into the freezer for a few hours to shrink them, but otherwise knock them in with the same brass hammer.removing the left axle and having trouble getting any leverage to remove the 9 bolts attached to the carrier assembly inside the banjo help
something tells me you are attempting to take the carrier apart inside the housing. it does not come apart that way. remove the right hub and slide the carrier out to work on it. than you can take the carrier apart. if you can get access to you tube. there is a lot of information on there.
