Daveyjonez
Hi All:
I am about to swap my tired 59a for an 8cm that I have put together, with early front dress (cam/ cover/ water pumps/ pulley/ crab/ etc.) I have the truck bellhousing for the later motor also. This will be going in my 34 5 window.
I will be running my existing 39 trans- couple of questions:
I know I can get the clutch kit from Fort Wayne to adapt early clutch stuff to the later flywheel- I have the Merc flywheel that came w/ my core 8cm, can I run that? Is there a better flywheel that I should consider?
Also, any other "heads up" information that will prepare me in advance??
Thank You!
Dave
Thank You!
Dave
