8CM(merc) vs 8BA(ford)..differences Q
The Mercury has a 4" stroke crank, making it 255cid, as compared to the Ford's 239cid from its 3.75" crank. The Mercury's 8CM heads are a bit low on compression, and it has what some call a back draft carb which utilizes a 4 bolt base. Basic blocks are the same. As far as desirable, many would rather have the 4" crank and extra cubes.
