8CM camshaft
These are the exact reasons I decided to keep the stock cam in my Mercury engine instead of installing an aftermarket cam. I have a relatively heavy car ('51 Ford) so the Merc cam seems to an all around better choice. I also second checking out the Tilden site. It has a lot of good information.
NOS 8CM cams are difficult to source. A regrind on a used one is an option. FoMoCo made a lot of EAB cams for replacements but not many 8CM ones. The EAB was made for the later valves but will work for the early ones too and is good for low end torque. It was made to work with the O-Matic transmissions and they needed the torque.
If anyone needs/wants an EAB cam, I have one and give it you for the cost of shipping.
One of the lobes has a chip in it, but I'm certain a good cam grinder can fix it without any worry. PM if interested.
