8cm cam grind
That makes a lot of sense. The automatic transmission would seem to me to require a milder cam for a smoother idle to accommodate idling in gear when stopped. Maybe, maybe not.
May I ask if there is a (best) stock cam for the pre 8ba style motors with the front mount dizzy?
Just out of curiosity, does anyone know if there are "1CM" ('51 Mercury) or "EAC" ('52-'53 Mercury) separate grinds?
I dug through my cam charts and found that I did degree a couple 1CM cams and for all practical purposed they are identical to the 8CM.
In my opinion, yes; the 32-34 steel cam. In 1935 with the introduction of the bigger, heavier bodies, along with cast iron camshafts, Ford 'detuned' the cam timing.
Only some;
year engine valve lift inches intake opensBTC intake closesABC exhaust opens BBC exhaust closesATC
32-34 V8 85 .292" 9.5 * 54.5* 57.5* 6.5*
35-42 V8 85 .292" 0.0* 44.0* 48.0* 6.0*
46-49 V8 100 .292 0.0* 44.0* 48.0* 6.0*
[1949 intake increased to .296" lift]
8CM that I degreed when building the 260 Merc:
9* 53* 50* 7* (checked at .014/.015 lash)
.330 lift at 0 lash
Compares nicely to the 32-34 cam Brian posted above. I think it'd be nice with the front modified for the early engine. An EAB cam is also very close to these numbers when advanced 4 degrees.
Terry
Only some;
Any ideas what lift these numbers were taken at?
You can install an 8ba style cam in an early block and front cover. Then you can run a late style distributor. W do this all the time
