Hi again folks. Jim here in Orrington Maine. My 37 Ford pickup came to me with an 8ba engine. It runs great but has a weak stomach. When running over 45 mph she warms up to 180 and pukes out the rad cap until it gets to 3 quarts low on antifreeze and stays there and doesn't get any hotter. There is no overflow tube on the radiator. There are no thermostats. The rad is clean and has great flow. Is this normal? I have driven it at 50 for a 200 mile tour and it never over heated. Outside temp was 75. What do I need to do?
Hi Jim, The radiator and engine was designed to run with 22 quarts or a full radiator filled up to the filler neck. Anything less will amount to running hot,
the lower the water the hotter it will run. Thermostats do nothing to cool an
engine, only make it run at or above the stats temperature ratting. You have two problems, the resistance of 144 radiator tubes, length of them and maybe a little dirt in them. The stock pumps each deliver about 65 gallons per minute of coolant through the system. But this is reduced by the back pressure from the radiator. The solution is better pump pressure with more flow capacity. Skips pumps deliver 110 gallons per minute each at a higher pressure. The close tolerance and larger streamlined impellers in the head mounted pumps and the new turbine impellers in the 37 to 53 allow every
pump Skip modifies to produce the exact same flow and pressure. Every pump is tested for at least 5 minutes on a water pump test machine and recorded in a log book. Also in over 10,000 pumps NO ONE has ever had
to pay for repairs. Now due to the radiator restriction the coolant has to be FORCED through the system and in order to do this you need a WORKING pressure cap or a tight sealing stock cap and Skips 3 lb pressure valve. A pressure cap is best but the 3 lb valve which must be removed at least once
a year and back flushed with a hose is the other way. The 3 lb valve holds the normal temperature pressure but opens as a safety valve is pressure is over 3.5 lbs due to over heating above 210 or a compression leak into the
coolant. People using the valve have reported not loosing or adding coolant
in over a year. G.M.
