52cruiser
Well I had the 8ba in my 52 customline rebuilt this past winter. Pretty much just a stock rebuild, I ended up having it bored .060 over and put a Canadian single barrel aluminum intake on it with the stock carb and an aluminum timing cover. I had the machine shop check and reuse my stock cam and lifters to save some dough but they had to grind the end of the new stainless valves to achieve the right lash. I'm really happy with the way everything turned out, its running great and sounds great. I'm just having some problems some where in the carb. As the title goes the engine is stumbling only at 65+ mph at a constant throttle (I don't have a tach in my car but i'd guess the rpms are at around 2,000) and at high rpms in first gear. I can free rev it in the garage with no problems as well as wind it up through second gear with no issues at all. It just pops out the exhaust and stumbles when I have the problems. The only remedy I've found is to pull the choke half way out at 65+ mph and it runs great. So some how its running lean. Here's the list of stuff I already checked:
- timing is dead on (I did disconnect the vac. advance to check this)
-vacuum advance is working and holding vacuum
-I have pertronix instead of points and it seems to be doing its job
-I rebuilt the carb prior to installation, new power valve tested good and I have 51 jets. (does that mean .051"?????)
-float level is dead on
-20" of vacuum at idle
-adjusted air/fuel mixture screws to achieve highest vacuum at idle
-Idle is not irradic and vehicle runs GREAT except when stated above
So my thoughts are bigger main jets, if anyone could let me know what the next bigger size recommended is? Also it seems kinda weird to me that the jets were never an issue before the rebuild, could it have something to do with the ethanol fuel and the fresh engine with good compression?
I know there's someone on this board that will think of something I haven't checked! Thanks guys, the info is greatly appreciated!
