Flathead dragster: 296cid, Potvin 425 eliminator, four 97's on gasoline, vertex mag, a lot of valve, port, and head work, stock rods, stock main caps with fabricated steel supports. Told the young (but good) driver to shift around 5500 RPM. It would run the quarter in the high 12's. Then one day he decides to run it out till it stops pulling and then shift. Well he ran it to 7000 RPM before shifting, car went 12 flat. After that, 7 was the new redline. Many races no engine problems or tear downs. Believe it or not, but a true story.
