Joe AZ
I've pulled my '40 engine, which has been updated with 8BA rods, one piece valve guides, etc.
When removing the bearing shells, I noticed that not all of the rods have the small hole drilled, which lines up with the hole in the bearing shell.
I also noticed that at least one journal has a rod with the drilled oil hole.
Is the theory that both shells on one journal can receive oil from one rod, or should I drill those that haven't been?
Not an engine builder, but trying to learn!
Any opinions would be appreciated.
Joe
Joe
