Chuck Kuntz
I am working on a 59AB motor that had the later 8BA crank and rods installed. I see that the Ford shop manual states that the oil squirt holes should face forward, but the Chilton manual says that the rod bearing tangs should the to the outside of the motor. On cylinders 1 thru 4, this means that if the holes are forward the stamped numbers on the rods are facing the center of the motor and the tangs are to the inside of the motor. What is the proper orientation for these rods????? Another question is that I want to put this in a 1933 Tudor and need to know what crankshaft pulley should be used. It appears that the standard 8BA would hit on the front cross member. The 8BA crank uses a spiral grooved sleeve to direct oilflow backwards. This motor had been in a 41 ford so it had the long snout pulley with the fan. Obviously I can't use that on the 33. Thanks for any info you can offer.
