8BA road draft tube OD
Or the ID of the hole in the manifold for the road draft tube ?
Looks like 1 5/8" or so?
Thanks.
Not sure the exact dimension, but if you're possibly looking for a way to block it off for a PCV Valve mod, a Dorman #555-023 freeze plug is a perfect fit. Link to the thread if you're interested. DD
https://www.fordbarn.com/forum/showthread.php?t=284487&highlight=v8coopman+pcv+valve
436863
436862
436861
I believe he is asking about the size of the exterior tube on an 8BA type manifold.
Are they the same?
Naw. When the engine gets back from H&H I'm going to install a ME Wagner PCV valve on it........ I refuse to buy an aluminum plug for $40 (Jamco) when I can machine a remnant piece of 6061 in 5 minutes.
or you could use a freeze plug, inverted, braze a fitting on it for the pcv...
Karl
