cadillac512
Cadillac512 and Tubman,
Thanks for the comments. I re-did the math to get a preliminary wear of between .0025-.0045 in the bores. Still need official measurements especially taper. But if I'm at the wear indicated a re-ring would be fine? Not trying to build or drive crazy but it will get what it needs. Price isn't the issue but what does it need....
I just finished a 260" Merc (4" stroke/.030" over bores) for my '41 Merc. The block had been bored in the past and was worn .003"-.004" at the tops of the cylinders but pistons were fine. I reamed the ridge at the bore tops and honed lightly to break the glaze. Put it back together with a set of Hastings cast rings,leaving the bottom oil ring off the 4 ring pistons. I have 1500 miles on it in the last couple months and it runs great and uses no oil. No piston noise either.
I completely disassembled the engine and cleaned it ( hot tanked and crack checked )same as if it were getting a full-on rebuild. All new bearings and clearances checked.
If yours checks out I'd sure do the same if it were me. Be sure to check the top ring lands for wear!
Terry
