51f1truck
I installed a new fuel pump from MAC's about 3 months ago on my '52 8BA 239 ci flathead. After installation, the engine ran like a champ starting well and running well. Took it out for a drive today and only made it out of the driveway. After a few hours or work, I found that there was no fuel pressure.
I took off the pump and inspected the components. The main diaphragm is fine. It appears that the one way valves are leaking by. I can blow air from the inlet to the carb (the way gas is suppose to flow) but also from the carb to the inlet (not good).
Has anyone else experienced pump problems like this? How did you solve it? Is there a better source for a new pump?
I do not want to install an electric pump at this time. My gas is very clean since I also installed a new tank and fuel lines during the restoration. The glass fuel bowl showed crystal clear gas.
Looking for some wisdom. I hate to have to replace a fuel pump every 3 months!
Thanks,
Fred
Thanks,
Fred
